Setting the height property (under “Position” grouping) for components inside of a Breakpoint view to the relative viewport height (vh) results in the designer highlighting an error on the property. The vh values work correctly in changing the component heights, just an issue with the incorrect warning in the designer.
Ignition 8.1.5 (maybe fixed in more recent releases?)
