Ignition 7.9.1
I have a tab strip where I’m hiding tabs based on property values using the cell update binding.
When I add cell bindings to the ‘visible’ column of particular tabs, i select the ‘Value’ field for the new Cell Bindings row, click on the ‘Insert property value’ button, select my property and press OK, and nothing appears in the Value field… I can type the expression in manually and it accepts it, but I can’t use either of the selection tools (property or tag). I’m sure that this use to work back in 7.9.0
Edit: it seems to not work only when i’ve double clicked on the input box first. If I single click on the value field and then select the insert property value, it then works. Still seems like a bug to me…
