[Bug] Chart Axis label position issue
Hi i have 2 dataset in my chart. each have separete axis
i want to right side axis label name should be positioned same as left label name
Is there any way to fix this?
I'm not sure that I understand what you are asking? Is the picture how you want it to look, or is the picture the problem?
I believe I see what you are talking about. You want the label to face the same way like this:
The assumption would be that you would simply set your axis label angle to 180 degrees, but that doesn't work:
...because it looks like somebody forgot to take their calculator out of radian mode. :rofl: Consequently, 180 degrees ends up being pie in the chart customizer. Set the Axis Label Angle to 3.14, and you will achieve the desired result.
