[BUG]"columnNames" Parameter Not Working for Tag History
Issue Description:
When defining the “columnNames” parameter for the “system.historian.queryAggregatedPoints” function, the resulting dataset does not use the value of “columnNames” for its headers but instead the default header names. I tested this in a Python script within the Reporting module and the Script Console.
Expected Behavior:
The resulting dataset should have its headers replaced with the list of strings defined in “columnNames”. The function does return an exception when the length of the list is not correct, which is expected.
I was able to replicate the “columnNames” functionality with the “setColumnNames” dataset method in my script, but I don’t know why the parameter in the function does not work.
Ignition Version: 8.3.1
Please post your test script and see Wiki - how to post code on this forum.
I think you need to account for the first column in the return dataset. IIRC, it’s a ts/t_stamp column.
How many columns are in your return dataset vs your columnNames?
Looks like things have changed since I last used the Historian module (8.1). After testing in 8.3.1 you no longer need to include the timestamp column.
This is the code I was using to test in the Script Console:
histPath = "histprov:NBU_Main_DB:/sys:NBU_Main:/prov:NBU_Main:/tag:_Gateway/Performance/CPU Usage"
tagPath = "[NBU_Main]_Gateway/Performance/CPU Usage"
output1 = system.historian.queryAggregatedPoints(
	paths = [histPath],
	startTime = system.date.addDays(system.date.now(), -1),
	endTime = system.date.now()
print("Dataset with default headers: ")
print(output1.getColumnNames())
print(list(output1))
output2 = system.historian.queryAggregatedPoints(
	paths = [histPath],
	endTime = system.date.now(),
	columnNames = [tagPath]
print("Dataset with new headers: ")
print(output2.getColumnNames())
print(list(output2))
Result:
[t_stamp, histprov:NBU_Main_DB:/sys:NBU_Main:/prov:NBU_Main:/tag:_Gateway/Performance/CPU Usage]
[[Sun Nov 23 15:46:41 CST 2025, 0.13377929849728076]]
[[Sun Nov 23 15:46:41 CST 2025, 0.13377952958085207]]
I’m only using one column in columnNames because I get an exception when adding more.
Example:
	paths = [histPath],
	paths = [histPath],
	columnNames = ["t_stamp", tagPath]
Result:
[[Sun Nov 23 15:48:34 CST 2025, 0.1348958872269098]]
Java Traceback:
  File "<input>", line 13, in <module>
	at com.inductiveautomation.historian.common.scripting.AbstractHistorianFunctions.queryAggregatedPoints(AbstractHistorianFunctions.kt:200)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: The paths and columnNames lists must be the same size
	at org.python.core.Py.JavaError(Py.java:545)
	at org.python.core.Py.JavaError(Py.java:536)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:563)
	at org.python.core.PyObject.__call__(PyObject.java:400)
	at org.python.pycode._pyx42.f$0(<input>:21)
	at org.python.pycode._pyx42.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1703)
	at org.python.core.Py.exec(Py.java:1747)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: The paths and columnNames lists must be the same size
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 18 more
The stacktrace says:
Here's why.
Tip: When confronted to a java stacktrace, look for the lines that start with "caused by"
After testing in 8.3.1 this doesn’t seem to be the case.
The manual states for columnNames A list of alias column names for the returned dataset which isn’t true (it was true for 8.1 at some point). To alleviate future confusion it should note the columnNames length needs to match the paths length.
That being said, I could replicate the error issue if histPath contained a capital letter. If the path is all lowercase, then the columnNames work (note: the returned columnNames will also be lowercase).
@mjadams to test this add .lower() to the histPath. histPath = "histprov:NBU_Main_DB:/sys:NBU_Main:/prov:NBU_Main:/tag:_Gateway/Performance/CPU Usage".lower()
That seems to be the problem. It works for me if the histPath is lowercase.
However, I don’t know if this is intentional or not. The QueryTagHistory function, which is deprecated but still exists in 8.3, had a columnNames parameter, and it works with capital letters.
FWIW, when displaying datasets you’ll typically use a table or some component that offers column settings to style, adjust, rename columns, etc. Intentional or not, these workarounds are simple to implement.
Another (not working) example in Ignition 8.3.2 (the code I have commented out is a good work around for changing the column names until this [BUG] gets fixed):
	sTagPath = "[TestTags]adamtest/ain01/valuecurrent"
	sStartTime = "2026-02-02 16:07:00"
	sEndTime = "2026-02-02 16:17:00"
	dtStart = system.date.parse(sStartTime)
	dtEnd = system.date.parse(sEndTime)
	iDiffSeconds = system.date.secondsBetween(dtStart, dtEnd)
	ds = system.historian.queryAggregatedPoints(paths=[sTagPath], startTime=dtStart, endTime=dtEnd, aggregates=["LastValue"], columnNames=["AIN01"], returnSize=iDiffSeconds)
	csv = system.dataset.toCSV(ds)
	#lHeader = ["timestamp","AIN01"]
	#lData = [row for row in ds]
	#dsCSV = system.dataset.toDataset(lHeader, lData)
	#csv = system.dataset.toCSV(dsCSV)
	sFileName = "C:\\Users\\Public\\chartdata20260202.csv"
	system.file.writeFile(sFileName, csv)
Ignition Platform 8.3.2 (b2025120210)
Twilio Integration and Alarm Notification Module 4.3.2 (b2025120210) Trial
SFC Module 6.3.2 (b2025120210) Trial
SQL Bridge Module 11.3.2 (b2025120210) Trial
OpcCom Module 7.3.2 (b2025120210) Trial
Perspective Module 3.3.2 (b2025120210) Trial
Reporting Module 7.3.2 (b2025120210) Trial
Symbol Factory Module 8.3.2 (b2025120210) Trial
Alarm Notification Module 7.3.2 (b2025120210) Trial
OPC-UA Module 10.3.2 (b2025120210) Trial
Enterprise Administration Module 5.3.2 (b2025120210) Trial
Legacy DNP3 Driver Module 5.3.2 (b2025120210) Trial
Historian Core Module 1.3.2 (b2025120210) Trial
Vision Module 12.3.2 (b2025120210) Trial
  • Connected Gateway: http://localhost:8088
  • Java Version: Azul Systems, Inc. 17.0.16
  • JVM Memory (used/max MB): 814.0 / 1,024.0
  • Client Time Zone: America/Chicago [GMT-6:00]
  • Gateway Time Zone: America/Chicago [GMT-6:00]
If this is the same bug fixed in 8.3.4 for queryRawPoints then you might see if the RC or nightly version fixed it. Stable version should release later this month.
