Dear all,
I am currently using the build b2019030402.
When I open the designer, I suddenly receive the following error:
09:11:44.864 [AWT-EventQueue-0] WARN ignition.ProjectDialog - Unable to list template projects. Check internet connection.
java.util.concurrent.ExecutionException: java.net.ConnectException: Connection timed out: connect
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.ignition.designer.ProjectDialog$OpenOrCreatePanel$ProjectCreateForm$7.done(ProjectDialog.java:594)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: connect
at java.base/java.net.PlainSocketImpl.connect0(Native Method)
at java.base/java.net.PlainSocketImpl.socketConnect(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at java.base/sun.security.ssl.BaseSSLSocketImpl.connect(Unknown Source)
at java.base/sun.net.NetworkClient.doConnect(Unknown Source)
at java.base/sun.net.www.http.HttpClient.openServer(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsClient.(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.designer.ProjectDialog$OpenOrCreatePanel$ProjectCreateForm.fetch(ProjectDialog.java:634)
at com.inductiveautomation.ignition.designer.ProjectDialog$OpenOrCreatePanel$ProjectCreateForm$7.doInBackground(ProjectDialog.java:585)
at com.inductiveautomation.ignition.designer.ProjectDialog$OpenOrCreatePanel$ProjectCreateForm$7.doInBackground(ProjectDialog.java:581)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
May I do something?
Thank you.
