[BUG] Copy/Paste of Python code doesn't maintain correct tabs
This has been bugging me for a while, but when you copy and paste Python code, the first line has the correct position, however the following lines of code are all indented.
Example below, I copied this:
And when pasted into another script at the same indentation as the cursor in the above shot, I get this:
We’re in the process of replacing all the code editors in the designer, which will likely solve this problem (and equally likely, replace it with a bunch of different ones :slight_smile: ).
the new code editor will be for 8.1 only or for 8.0 too ?
Not sure yet. Likely 8.1.X.
Yes there are huge expectations for the new editor :man_mechanic:
I am on 8.1.48. Did the improvements mentioned here happen? I really wish the scripting used Bython, the tab/space issue is frustrating. What is the best way to make sure scripts have tab indentation when it needs to? The editor in 8.1.48 does not show a difference and it would really help to indicate something that helps debug for this
Just checking, but are you aware that the editor can show tabs and spaces?
That’s it! I didn’t know, but now that I do it is a great help
