On a popup window, I have a button with the option “Default Button” set to true, which usually makes the button background blue, etc. but often the checkbox is selected but the button looks like a normal one:
And I have to remove and set the Default button option so it applies back again:
Notes:
- It’s the only button on the popup with this option set.
- The bug is just a graphical issue on the designer, the look is correct on the client.
- This apprears every time I go to another part of ignition designer’s project browser (example: I’m on vision, displaying the popup window, then I go to the named queries, or the scripting or any other view that “hides” the windows), and when I go back to viewing the popup, the default button style is gone.
- It is also possible to only just close the popup and open it again to have the default button style correctly applied again.
