If you have an Edge on a network, specifically in my case a Raspberry Pi running Edge, other machines on the network will automatically find the gateway on the Pi, but instead of filling in the actual address it found it at, it fills in 127.0.0.1. FYI could be because the Pi only has WIFI enabled and the eth0 port is not connected, and it is using the address of eth0 instead of the WIFI.
