[Bug-Duplicate]Errors Occur when adding Navigation event
i have a script taking inputs and then passing them into session custom properties which works fine in by itself in a button. when adding a navigation action after the script it seem to through an error on the log (see below):
The navigation action works correctly however the script does not fire.
ClientSession	20Jan2019 10:14:51	Received event for missing view "Main/Maintainance/StartCard@C"
Version: 8.0.0-beta0 (b2019011702)
Server: Windows Server 2012 R2
Confirmed on build b2019011102 as well. Script event action produces log warning when coupled with a navigation action:
ClientSession	21Jan2019 08:27:40	Received event for missing view "dev@C"
Appears to be independent of the action order in the event configuration (both Script action-> Navigation action and Navigation action -> Script action produce the same result).
I vaguely recall this being a known issue. The workaround was to only use the script action and have the script open the target view in addition to whatever else you need.
Found it… :grin:
http://forum.inductiveautomation.com/t/bug-11644-gateway-receives-events-for-missing-views/20866/12
