[BUG] EAM - Tag copy task failed due to insufficient tag provider edit permissions
Hello,
We have same problem on our environment : we need, on Remote Agent, leave blank "Tag Editing Permissions" in order EAM Send Tag works.
And I see other people are in same case :
I see than Nightly 8.1.30-SNAPSHOT-b20230712 have :
IGN-7597: EAM Send Tag Task fails if Tag Editing Permissions are set on Agent’s tag provider
Do you think than it's correcting our problem ?
Sounds like it will fix it :crossed_fingers:
Hello,
For information I have tested a nightly version 8.1.32, and the bug is resolved : I can push tag from EAM to a remote Realtime Provider when "Tag Editing Permission" is not empty.
Edit : but don't think EAM use security Edit define in Realtime Provider. EAM use Service Security configuration
I had the same error in 8.1.43 (EAM and gateway have the same version)
"Failed: Attempt 1: Access Denied. Remote tag editing is not allowed for tag provider 'MES' in the calculated zone."
I did all recommendations in this thread, but it did not work.
Any other thing that I can try ?
