[BUG] Export/Import of *Scheduled* Gateway Events not working
Using 8.1.29
From the Designer, if I export "Gateway Events" which include some "Timer" and "Scheduled" event scripts:
and then import that into a new project, "Timer" events are properly exported/imported, but "Scheduled" events seem to be ignored.
How do I export/import "Scheduled" gateway events?
Thanks.
-Shane
Sounds like a bug, worth reporting to support. Unless you are trying to import into an older version that didn't support scheduled events?
Same Ignition version (8.1.29), just trying to move them between projects without having to do a bunch of manual entry/updates.
A little follow up. It looks like "Scheduled" events ARE imported, they just don't appear in the designer until you close the designer and re-open it (unlike "Timer" events).
So maybe still a little bug-ish, but not completely not working like I thought.
-Shane
I've created ticket IGN-8998 for this bug. If you'd like to be notified when it's fixed, contact support and let them know.
