I'm trying to use the Find/Replace tool to rename things, but my view custom properties are greyed out. I'm using Ignition Edge, so this is a single project without any inheritance. Is this a bug?
Hi Andrew, this behavior is expected. We cannot replace the key of a custom property using the Find/Replace tool, which is why it’s greyed out. However, you can use the tool to find and replace the value of a custom property - if you search for the property’s value, it will not be greyed out.
