If I have the diagnostic window open, and then enter a value in a numeric entry in the window behind the diagnostic window, the diagnostic window disappears when I touch OK on the numeric keypad popup. (touchscreen is enabled)
It re-appears when I touch the numeric entry again, but I can’t interact with it because the keypad has focus.
I can’t bring it back into view with either Ctrl - shift - F7 or the Help / Diagnostic menu
My current workaround is to try and remember to close it before doing my numeric entry, and then re-open it after.
Or when I forget, shut down the client and restart it.
Using Ignition version 7.7.5
Vision module 7.7.5
