[bug: IGN-2719] 8.1.5 - Reporting - Simple table visibility not working when using dynamic data key
Hi, I’m having an issue with Simple table not hiding. I’m using the same data key to hide time series chart and other objects which seem to work fine.
In the below example, the rectangle hides when I don’t select a filter and when I do it becomes visible but the Simple table stays visible at all times:
I’ve been able to replicate this and have filed a ticket
any update on this?
No. This issue is still waiting to be picked up.
As a workaround, you might be able to embed the simple table inside of an unstructured row on a standard table component?
Any updates?
@paul-griffith
This worked for me.
