[BUG] Ignition designer crash on reports text label resizing
Hello,
I’ve encountered the following problem when building a report in the report design tab:
I am inserting a text element and putting any kind of text or database field in it, but when I try to resize it dragging the angle of the text shape with the mouse and make it smaller, if accidentally the size I’m trying to give to the shape is smaller then the text inside the text shape all the designer crashes and starts draining maximum CPU from my computer.
Does somebody else has the same problem?
Ignition version: 8.0.6
Reporting module version: 5.0.6
We just fixed a bug regarding text shapes “overflowing” like this - if you’re able to, try the latest nightly, or wait for 8.0.7 with the fix :slight_smile:
