A lot of Vision windows from my Ignition 7.9 project cant be saved in 8.0. The windows import and can edit them but every time I click save the little "Connection Restored" box notification flies in from the bottom, anything you do after this is never saved, quitting the designer and coming back in the windows and changes will not be there. The same thing happens if I upgrade the 7.9 project with the 8.0 installer you can never save anything in the designer.
The designer console shows:
[AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - Error reading updated project from Gateway.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error writing to server
... and
[PDT-Task-runner] WARN com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Connection to Gateway lost, due to exception.
Windows Server 2012R2
Beta version downloaded 11/30/2018
Attached is a single screen that causes the error every time I try to import it.
VOTickets.proj (161.5 KB)
