Observed issues deploying on Kubernetes with persistent volumes. Documents indicate mounting volumes to /usr/local/bin/ignition/data however in doing so, this effectively hides existing clean templates which are presented in the same folder. The result is a failure to launch as certain clean template files cannot be found (being masked out by the mounted volume). We see errors like this:
cannot stat '/usr/local/bin/ignition/data/gateway.xml_clean': No such file or directory
In reviewing the docker-entrypoint.sh script in the container I can confirm that this is designed well to deal with a fresh mounted volume and seeding it with a clean template folder. It functions as it should but providing the mounted volume is under /usr/local/bin/ignition/data and the default clean template data folder is under /usr/local/bin/ignition/data_clean. This should really only require a few lines to change in the Dockerfile.
Note, if an ephemeral instance is required (no volume mounts), then this works fine. The entrypoint script will initialise a new running instance with the default clean template files correctly.
A hack workaround I needed to implement is to mount to /data and then override the default entrypoint script run to be replaced with the following:
# Move the default clean template data folder to where its supposed to be
mv ${IGNITION_INSTALL_LOCATION}/data ${IGNITION_INSTALL_LOCATION}/data_clean;
# Create a symlink /usr/local/bin/ignition/data pointing to our persistent
# volume
ln -s /data ${IGNITION_INSTALL_LOCATION}/data;
# Resume original entrypoint to do the rest
docker-entrypoint.sh;
Creating this topic to share the workaround and to hopefully chase up a simple fix.
