I have 2 server with Ifntion 8.1.48 and max heap memory set to 10240 Mo
After upgrading to 8.1.49, memory is changed to 2048.
Same issue when upgraded from 8.1.47 to 8.1.48
I suspect the check of ignition.conf take 10240 for 1024 and reset to the default value 2048
Can you share the before and after ignition.conf files from your gateway?
I don't see any upgrade logic for any versions that targets the memory settings, so something else must be going on.
That's the "before" file?
That’s the file after the upgrade.
I only reset the value 2048 to 10240
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=10240
Can you provide the "before" file? From a backup taken before the upgrade or something?
