[BUG] Numpad not showing in Perspective in browser on iPhone for numeric entry
iOS 16.7.7
When I run Perspective in Safari or in Perspective Workstation, tapping on a numeric input component simply selects numbers but doesn't bring up the numpad. The text input component works fine.
I have experienced the same.
I figure it’s because I have the numeric input in an Embedded View.
If you activate the spinner on the numeric input component it will open normal keyboard.
I believe this should have been fixed as of 8.1.36. What Ignition version are you currently running?
Ok cool, I think they're running low 20s. I'll see if they want to upgrade, cheers
Is the numpad feature only available for mobile? I am running 8.1.36 on a Windows 11 machine and a numpad does not popup when selecting a numeric input component.
