Version 8.1.7 (b2021060314).
When importing session properties into Ignition, there are times (random) when not ALL changes show up after import. Importing the same file into other projects results perfectly.
Noticed that after import, saved and switched to another project, then back to current project, ALL changes showing up properly. The import executed just fine, it just didn’t display properly directly after the import.
