v8.1.5
For a colour prop e.g. [alarm]props.rowStyles.activeAcked.priorities.low.backgroundColor
If you set this value to:
hsl(0, 50%, 50%)
then it treats it as if you wrote:
rgb(0,50,50)
If you instead add a CSS var to your CSS theme:
--var-name: hsl(0, 50%, 50%)
and then set the prop value to this:
var(--var-name)
then it works correctly.
I always use HSL since it’s the most human-readable and interprettable.
