[BUG] Perspective copy paste component doesn't always copy all associated properties
v8.0.15
When I copy and paste the below json into a flex container, the “shrink: 0” doesn’t make it and it becomes a “1”. The basis doesn’t get set right either, should be “auto” but it pastes as “50px”. The json is from a copy of another existing component, screenshot below.
    "type": "ia.display.label",
    "version": 0,
    "props": {
      "text": "Status"
    "meta": {
      "name": "Label"
    "position": {
      "shrink": 0
    "custom": {}
Edit:
In addition, components aren’t pasted in the right order. See below, components should be in the order of “Status label” “Status value” “Current Step Label” “Current Step Value”, but instead it’s reversed.
Update: It seems that items are copied in the order in which they’re selected. I guess that makes sense.
    "version": 0,
    "props": {
      "style": {
        "backgroundColor": "#555555",
        "borderBottomLeftRadius": "5px",
        "borderBottomRightRadius": "5px",
        "borderColor": "#2B2B2B40",
        "borderStyle": "solid",
        "borderTopLeftRadius": "5px",
        "borderTopRightRadius": "5px",
        "borderWidth": 1,
        "color": "#E7EFF6",
        "paddingLeft": "5px",
        "paddingRight": "5px",
        "textAlign": "center"
    "meta": {
      "name": "Label_4"
    "position": {
      "shrink": 0,
      "basis": "30px"
    "custom": {},
    "propConfig": {
      "custom.Cancelled": {
        "binding": {
          "config": {
            "fallbackDelay": 2.5,
            "mode": "indirect",
            "references": {
              "1": "{view.custom.sequenceTagPath}"
            "tagPath": "{1}/Sequence Cancelled"
          "type": "tag"
      "custom.Complete": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
            "tagPath": "{1}/Sequence Complete"
          "type": "tag"
      "custom.Paused": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
            "tagPath": "{1}/Sequence Paused"
          "type": "tag"
      "custom.Running": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
            "tagPath": "{1}/Sequence Active"
          "type": "tag"
      "custom.StatusDesc": {
        "binding": {
          "config": {
            "expression": "if({this.custom.Running}, \"Running\"\r\n,if({this.custom.Complete}, \"Complete\"\r\n,if({this.custom.Paused}, \"Paused\"\r\n,if({this.custom.Cancelled}, \"Cancelled\"\r\n,'Idle'\r\n))))"
          "type": "expr"
      "props.text": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
            "tagPath": "{1}/Sequence Step Description"
          "transforms": [
              "expression": "tag({view.custom.sequenceTagPath} + '/Sequence Step No') + ' - ' + {value}",
              "type": "expression"
          "type": "tag"
    "version": 0,
    "props": {
      "text": "Current Step",
      "style": {
        "color": "#4B86B4",
        "fontSize": "10pt",
        "fontStyle": "italic",
        "fontWeight": "100"
    "meta": {
      "name": "Label_0"
    "position": {
      "shrink": 0,
      "basis": "30px"
    "custom": {}
    "version": 0,
    "props": {
      "style": {
        "marginBottom": "10px",
    "meta": {
      "name": "Label_3"
    "position": {
      "shrink": 0,
      "basis": "30px"
    "custom": {},
    "propConfig": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
          "type": "tag"
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
          "type": "tag"
      "custom.Paused": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
          "type": "tag"
      "custom.Running": {
        "binding": {
          "config": {
            "mode": "indirect",
            "references": {
          "type": "tag"
        "binding": {
          "config": {
          "type": "expr"
      "props.style.classes": {
        "binding": {
          "config": {
            "path": "this.custom.StatusDesc"
          "transforms": [
              "fallback": null,
              "inputType": "scalar",
              "mappings": [
                  "input": "Running",
                  "output": "DeviceStates/On"
                  "input": "Complete",
                  "input": "Paused",
                  "output": "DeviceStates/Paused"
                  "input": "Cancelled",
                  "output": "DeviceStates/Off"
                  "input": "Idle",
              "outputType": "scalar",
              "type": "map"
          "type": "property"
      "props.text": {
        "binding": {
          "config": {
          "type": "property"
    "version": 0,
    "props": {
      "text": "Status",
      "style": {
        "color": "#4B86B4",
        "fontSize": "10pt",
        "fontWeight": "100"
    "meta": {
      "name": "Label"
    "position": {
      "shrink": 0,
      "basis": "30px"
    "custom": {}
Yeah this is something I’d like to see fixed as well.
This one is actually quite annoying!! I find myself cutting components and pasting them into containers quite frequently, or just copying and pasting in general, and every time they lose their shrink and basis properties :frowning:
I filed a ticket for this. Seems like it should be an easy fix, I say as someone who hasn’t had to deal with Perspective internals in a while :slight_smile:
Definitely hanging out for this fix! When doing a lot of copy/pastes into flex’s this gets a bit tedious having to change the basis and shrink values to what they were copied from :dizzy_face:
