[BUG] Perspective designer not loading
The perspective options now appear in the project browser however when selecting a view the designer window does not render.
Build: 8.0.0-beta0 (b2019011302)
Designer: MacOS 10.14
Do you have any errors in the console?
It’s possible you’re experiencing the same bug as this post: http://forum.inductiveautomation.com/t/bug-problems-with-v8-on-google-compute-instance/21848/3?u=kevin.herron
i beleive so, here is my logs.
10:44:03.198 [Designer-Startup] INFO designer.main - Cleanup... [+159]
10:44:03.199 [Designer-Startup] INFO designer.main - Initializing UI... [+160]
10:44:03.266 [DesignerExecEngine-1] INFO tags.subscriptions - Changing connected quality to 'Good'
10:44:03.266 [Designer-Startup] INFO tags.manager.gwinterface - Tag poll rate changed to 250 ms
10:44:04.506 [Designer-Startup] INFO designer.main - Starting module: Vision [+1467]
10:44:06.636 [Designer-Startup] INFO designer.main - Starting module: Alarm Notification [+3597]
10:44:06.722 [Designer-Startup] INFO designer.main - Starting module: Symbol Factory [+3683]
10:44:06.732 [Designer-Startup] INFO designer.main - Starting module: Perspective [+3693]
10:44:06.812 [Designer-Startup] INFO Perspective.Designer - Starting up Perspective module.  Mode: Activated
10:44:07.068 [Designer-Startup] ERROR designer.main - Error starting up module Perspective
java.lang.ClassFormatError: Illegal field name "com.inductiveautomation.ignition.client.jsonedit.NodeEditor$this" in class com/inductiveautomation/ignition/client/jsonedit/NodeEditor$Expander
	at java.base/java.lang.ClassLoader.defineClass1(Native Method)
	at java.base/java.lang.ClassLoader.defineClass(Unknown Source)
	at java.base/java.security.SecureClassLoader.defineClass(Unknown Source)
	at java.base/java.net.URLClassLoader.defineClass(Unknown Source)
	at java.base/java.net.URLClassLoader$1.run(Unknown Source)
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor.initComponents(NodeEditor.java:347)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor.<init>(NodeEditor.java:253)
	at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentScopeEditor$BindingCompatibleNodeEditor.<init>(ComponentScopeEditor.java:179)
	at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentScopeEditor.newNodeEditor(ComponentScopeEditor.java:157)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor$ChildEditors.updateChildren(NodeEditor.java:1265)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor$ChildEditors.load(NodeEditor.java:1191)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor$ChildEditors.<init>(NodeEditor.java:1171)
	at com.inductiveautomation.ignition.client.jsonedit.NodeEditor.initComponents(NodeEditor.java:356)
	at com.inductiveautomation.ignition.client.jsonedit.JsonEditor.setModel(JsonEditor.java:121)
	at com.inductiveautomation.ignition.client.jsonedit.JsonEditor.<init>(JsonEditor.java:93)
	at com.inductiveautomation.ignition.client.jsonedit.JsonEditor.<init>(JsonEditor.java:83)
	at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentScopeEditor.<init>(ComponentScopeEditor.java:94)
	at com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame.createScopeEditor(PropertyEditorFrame.java:194)
	at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
	at java.base/java.util.Spliterators$ArraySpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame.<init>(PropertyEditorFrame.java:113)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.<init>(ViewWorkspace.java:107)
	at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:187)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:1961)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1091)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$loadProject$3(IgnitionDesigner.java:911)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
	at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:910)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler$1.run(IgnitionDesigner.java:2033)
10:44:07.068 [Designer-Startup] INFO designer.main - Initializing Scripting... [+4029]
10:44:07.087 [Designer-Startup] INFO designer.main - Initializing UI... [+4048]
10:44:07.095 [Designer-Startup] INFO com.inductiveautomation.ignition.designer.querybrowser.QueryBrowser - No default datasource set for project. Set default in gateway and relaunch project.
Looks to be the same. This should be fixed in the next nightly build that occurs.
Sorry about the double up.
Y’all are doing a fantastic job !!!
