v8.1.5
When using a View in a Layer (props.layers.ui.view), I have a coord container View with two components, a pump symbol and an alarm symbol. The alarm symbol is on top, highest Z-order. When shown on map, this shows up ok. When I change the zoom of the map however, the alarm symbol goes behind the pump symbol.
In Designer, first load map:
After zooming:
Actually even when changing between preview and design modes, the alarm symbol goes to back when in run mode and in front when in design. In the browser, it’s always shown behind the pump symbol.
Edit:
The pump symbol is an SVG I dragged on and embedded. If I wrap this inside its own coord container, then the issue goes away.
