[BUG] Perspective Popups that open on smaller screens don't resize content
v8.1.24
I found a bug where, if a popup that is wider than the viewport it's opened in (for example a mobile screen) and constrain to viewport is checked, then the popup will automatically resize, but its content won't. Scrollbars appear to view the rest of the contents of the popup. If you resize the popup however, even just slightly, the popup properly then sizes the content to the size of the popup and avoids scrollbars.
It seems that the automatic resize event isn't firing whatever event is supposed to resize the popup content as well.
Hello nminchin,
I was able to recreate this behavior pretty easily on 8.1.25 and I will be checking internally to confirm if this known bug or not, I will update this post when I have some results.
Has this problem been solved ?
It works if you don't write zero in RIGHT and LEFT position like screenshot below :
