Dear all,
I am currently running the b2019021702 build.
The following error occurs when I save in the designer:
12:33:01.536 [AWT-EventQueue-0] WARN Perspective.SessionProps - Unable to obtain session props for save.
java.lang.IllegalArgumentException: Resource cannot be overridden.
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.update(ResourceTreeNode.java:90)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createResourceInternal(DesignerProjectTreeImpl.java:197)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createResource(DesignerProjectTreeImpl.java:187)
at com.inductiveautomation.ignition.designer.project.DesignableProject.createOrModify(DesignableProject.java:168)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.commit(SessionPropsAdapter.java:98)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.WorkspaceRootConfig.commit(WorkspaceRootConfig.java:28)
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:243)
at com.inductiveautomation.perspective.designer.DesignerHook.notifyProjectSaveStart(DesignerHook.java:393)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1413)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1204)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.access$2600(IgnitionDesigner.java:188)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleSaveAction(IgnitionDesigner.java:2535)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.access$1100(IgnitionDesigner.java:1964)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$5.actionPerformed(IgnitionDesigner.java:2146)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Thank you.
