I upgraded my development gateway to v7.9.14. Everything was working fine while adding a couple of users with the management component. After adding a user an error popped up and the list of users went blank.
java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$UserTable$7.apply(UserManagementPanel.java:2789)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$UserTable$7.apply(UserManagementPanel.java:2785)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:652)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
at com.google.common.collect.Iterators.addAll(Iterators.java:361)
at com.google.common.collect.Lists.newArrayList(Lists.java:160)
at com.google.common.collect.Collections2$FilteredCollection.toArray(Collections2.java:217)
at java.base/java.util.ArrayList.addAll(Unknown Source)
at com.inductiveautomation.ignition.client.util.gui.AbstractCRUDTable$CRUDModel.updateItems(AbstractCRUDTable.java:879)
at com.inductiveautomation.ignition.client.util.gui.AbstractCRUDTable$Loader.done(AbstractCRUDTable.java:832)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
Ignition v7.9.14 (b2020042813)
Java: Azul Systems, Inc. 9.0.7.4
