[Bug] Powerchart properties misbehave and are hidden from the editor
Powerchart properties specific to modes (xTrace, panAndZoom, etc) are hidden from the props/interaction/ menu if their mode is not the selected one. However, they ARE still attached, and sometimes applied, to the chart. This, in itself, is intentional behavior: Perspective: PowerChart Component - Config - Hidden Properties or Missing Properties ( 8.1.0 ) - #2 by paul-griffith, however, it can quickly lead to undesirable behavior.
In particular, xTrace's infobox and line can appear even when the xTrace mode is not selected. Without switching the editor's mode to xTrace, the properties to disable these are hidden from the editor. In addition, since buttons allowing clients to change modes are possible to enable, the configuration of these modes should not be hidden from the editor. This means clients can end up in unconfigured chart modes easily, if the mode switching is left enabled.
Bug Report
Version Info
Module Version License
Ignition Platform 8.3.8 (b2026071409)
SFC Module 6.3.8 (b2026071409) Trial
Event Streams Module 1.3.8 (b2026071409) Trial
Perspective Module 3.3.8 (b2026071409) Trial
Reporting Module 7.3.8 (b2026071409) Trial
Symbol Factory Module 8.3.8 (b2026071409) Trial
Alarm Notification Module 7.3.8 (b2026071409) Trial
OPC-UA Module 10.3.8 (b2026071409) Trial
Enterprise Administration
Steps to reproduce
  1. Add powerchart to a view
  2. Switch to live mode
  3. Add a data source and switch to xtrace mode
  4. Click the plot go add a line
  5. switch back to panAndZoom mode
Expected behavior
The xTrace elements are removed from the graph, and/or attributes that remain can be edited through the property editor.
Actual behavior
The xTrace elements remain on the graph, and the attributes for them are hidden from the editor.
Actual bug reports need to be made in a support ticket, if you want them seen reliably. This forum is mostly volunteers, including volunteer IA staff, and is not support (for most cases).
I wouldn't call this a bug; more so undesired designed behaviour. I agree that it's annoying that the unselected mode configs aren't shown. You shouldn't need to select the mode you're after to configure it while designing it
As such, I'd put this on the ideas portal and post here for visibility for more votes
