[Bug] “Production is not started” Error During Project Launch
I’m using Ignition MES version 8.1.40, and I encountered an error message when trying to launch my project. The error message appears: “Production is not started. Ensure install steps are complete.
Is the MES production module running? Check the modules section of your gateway config.
FYI Sepasoft is a third party, they are not Inductive Automation and for the most part you will have more luck contacting them for support directly.
