[BUG] Project Library is fully deleted on revert change
Version: 8.1.33
FYI, I have found an annoying bug that I haven't seen posted anywhere. Not sure if this has been resolved in newer versions yet either.
Expectation:
Only revert change without deleting scripts.
Behavior:
When you revert a change, all project library scripts are deleted.
To replicate:
  1. Make a change to a script in your project library
  2. ctrl + shift + s to save your changes
  3. Cancel the save
  4. Right click on a script you edited
  5. Select revert changes.
I believe this should be fixed as of 8.1.34/35.
Version: 8.1.30
I have seen a similar issue with views being deleted. Maybe it's the same as the script issue?
Here are my views before:
If I make a change to the view, then close the view, then choose to Revert Changes:
Then confirm, yes:
All of my views are deleted:
-Jon
Yes, the bug was with the project browser overall and its treatment of the 'revert changes' action. As Alec mentioned, the core issue is fixed in 8.1.35; there was a minor edge case that just recently got fixed, but it's not nearly as severe.
