I encountered this behavior after I deleted a data source property on an xy-chart.
1. The behavior you unexpectedly encountered - Got a Warning: “PropertyReference failed to read value.” after an xy-chart data source property was deleted.
2. The behavior you were expecting to see - expecting the binding would delete with the property.
3. A list of the steps you took that exposed the issue - After seeing the warning in the gateway log. I went back and added the property back in with the same name. The binding re-appeared. So I deleted the binding and then deleted the property. That got rid of the PropertyReference warnings.
- The Ignition version number: 8.0.14
- The browser and version number: Chrome 90.0.4430.93
- The Module name and version number: Perspective 1.0.14
