Hi
I am currently using version 8.0.15. I am not sure whether the below behavior would be classified as a bug or feature request.
Behavior Experienced: When multiple public addresses are entered into the Public Address filed under Public HTTP Address section, the client can not parse the redundant address correctly.
Behavior Expected: The client should parse the redundant address as a list and try to bind the one that can be resolved.
List of step to reproduce:
- Setup two ignition gateways, each with subnet 1, subnet 2 and subnet 3.
- Configure redundancy with network bind to subnet 1 or using a computer name
- Configure webserver with Public Http address auto detection off.
- Fill in the public address with subnet 1, subnet 2 and subnet 3 addresses, separated by comma.
- Ensure redundancy is working between gateways.
- Create an empty project with designer.
- Launch vision client and add the project. Close the vision client after project is added.
- Visit the launcher log and I see the unable to parse redundant address warning.
- Start the vision client, after open diagnostics, i can see the client can not resolve the backup connection.
I have attached several images with gateway information based on different configurations for your reference.
Regards
