1. The behavior you unexpectedly encountered - Changing the order of a new script will change the first item to a script from a popup.
2. The behavior you were expecting to see - The popup should remain a popup.
3. A list of the steps you took that exposed the issue
- Opened the event configuration for a component containing: 1. Popup and 2. Script
- Added a new script
- Hit the up arrow twice in quick succession to move the new script to the top.
- The popup becomes a script.
Just moving a script up and down through a list of >3 actions will cause the actions to be replaced by copies of the script. Even other scripts.
4. A list of helpful information about the situation you were in, such as:
- Ignition Platform 8.1.17
- Perspective Module 2.1.17
- Designer Launcher 1.1.14
