Bug Report Ignition 8.3.4 - system.historian.storeDataPoints
Hello,
I think there is bug in the implementation of system.historian.storeDataPoints.
My setup is basically Ignition Edge 8.3.4, using Internal Historian.
If i use storeDataPoints to write a value into the historian with timestamp A for the first time (no existing real tag) and then write another value for the same tag with timestamp B (where timestamp B is earlier than timestamp A) I see the following in the logs:
This appears to be an unhandled exception.
I running the following script inside script console:
GOOD_QUALITY = 192
path_flow = "Type3/008/Flow"
sample_rows = [
("2026-03-20 09:17:16", 44),
("2026-03-20 09:29:15", 55)
paths = []
values = []
timestamps = []
qualities = []
for ts_text, flow in sample_rows:
   ts = system.date.parse(ts_text, "yyyy-MM-dd HH:mm:ss")
   paths.append(path_flow)
   values.append(flow)
   timestamps.append(ts)
   qualities.append(GOOD_QUALITY)
   qc = system.historian.storeDataPoints(
   paths=paths,
   values=values,
   timestamps=timestamps,
   qualities=qualities
print "QC:", qc
print "Code:", qc.getCode()
Could please confirm if this is indeed a bug?
Yeah this is unexpected. I’ll file a bug ticket for us to fix this. Thanks for bringing it to our attention.
