Bug Report: Imported UDT's with a folder structure do not show up when trying to make new tag instances
I imported a folder of UDTs into a project, and I could not create a new tag instance with them:
When I renamed the folder they showed up:
However, when I tried to change the folder back to the original name, it did not show up and the new name persisted. I was also unable to see any of the actual data types to use them:
Apparently I can only include 3 images, so you just have to trust me on this one
I'm curious if anyone else is experiencing this, and if they have found a way to use the original name.
Have you tried hitting the little refresh button next to the provider selection?
I did, no luck. I also tried restarting the designer and re-importing the UDT's
Probably worth opening a ticket with IA. Might be corruption in your internal database, but might also be a bug worth reporting.
I haven't dealt with this community much. I genuinely thought this was the place to report bugs. Is there somewhere else to look for that?
Open a ticket with support here and they'll work with you on it:
https://support.inductiveautomation.com
More direct link:
https://support.inductiveautomation.com/hc/en-us/requests/new
