[Bug] Report paths for gateways on non-windows systems produce badly behaved paths
Setup
Version Info
Module Version License
Ignition Platform 8.3.8 (b2026071409)
SFC Module 6.3.8 (b2026071409) Trial
Event Streams Module 1.3.8 (b2026071409) Trial
Perspective Module 3.3.8 (b2026071409) Trial
Reporting Module 7.3.8 (b2026071409) Trial
Symbol Factory Module 8.3.8 (b2026071409) Trial
Alarm Notification Module 7.3.8 (b2026071409) Trial
OPC-UA Module 10.3.8 (b2026071409) Trial
Enterprise Administration Module 5.3.8 (b2026071409) Trial
Legacy DNP3 Driver Module 5.3.8 (b2026071409) Trial
Historian Core Module 1.3.8 (b2026071409) Trial
Vision Module 12.3.8 (b2026071409) Trial
SQL Bridge Module 11.3.8 (b2026071409) Trial
Kafka Connector Module 1.3.8 (b2026071409) Trial
WebDev Module 6.3.8 (b2026071409) Trial
I am running the Ignition gateway through a container (WSL2-based) on a Windows system. I am running Ignition Designer on Windows
Steps to Reproduce
  1. Open designer to a project
  2. Create a new report
  3. Under schedule, go to actions
  4. Enter a valid Linux path. Examples below.
Expected Behavior
Designer should accept the valid path.
Actual behavior
Ignition throws an error:
Attempted Action could not complete.  WARN: Error in running distribution Save File for report ReportName-- Unable to write PDF to file '/usr/local/bin/ignition/my-example-path/file.pdf
Additional examples
For simplicity, anytime the %% appears below, it is the /usr/local/bin/ignition/ directory on the container system. In addition, I will try having the filename as outputs/today/file.txt.
Folder Path Result
~/folder Fail, and %%/~/folder is created (yes, ~ is the name of the folder)
folder Fail, but %%/folder/outputs is created
C:/folder Success, output to %%/F:/folder/outputs/file.txt, there F: is the name of the folder.
/home/ignition Success, output to /home/ignition/folder/outputs/file.txt, as expected.
As shown, the behavior is wildly inconsistent. It can write to it's %% folder, but ONLY if it is using a "Windows path". Additionally, even on failures to save the file, the folder paths are still created, even if they use reserved characters.
