I tried to install the 32bit Version in a VM (Win7 32bit). On the VM was a 7.9.8 installation before, and it worked just fine.
I removed the old one and installed the 32bit Version of 8.0 beta. But I couldn’t finish the installation because of this error:
Window Title: GCU An error occurred while starting the application. Run with --l4j-debug to generate a log file.
so I did, and in the log was this:
Version: 3.10
CmdLine: C:\Program Files\Inductive Automation\Ignition\gcu.exe --l4j-debug
WOW64: no
Working dir: C:\Program Files\Inductive Automation\Ignition\.
Java min ver: 1.8.0
Java max ver:
Bundled JRE: lib\runtime\jre-win
Check launcher: C:\Program Files\Inductive Automation\Ignition\lib\runtime\jre-win\bin\javaw.exe (OK)
Main class: GatewayControlUtil
Add classpath: lib\*.jar
" : lib\wrapper.jar
Launcher: C:\Program Files\Inductive Automation\Ignition\lib\runtime\jre-win\bin\javaw.exe
Launcher args: -classpath "catapult.jar;lib\wrapper.jar" GatewayControlUtil
Args length: 60/32768 chars
Error msg: An error occurred while starting the application. Run with --l4j-debug to generate a log file.
Error: Die Version von %1 ist nicht mit der ausgeführten Windows-Version kompatibel. Öffnen Sie die Systeminformationen des Computers, um zu überprüfen, ob eine x86-(32 Bit)- oder eine x64-(64 Bit)-Version des Programms erforderlich ist, und wenden Sie sich anschließend an den Herausgeber der Software.
Open URL: http://inductiveautomation.com
The installation of 7.9 worked fine on the same machine. I tried also the same on a 64bizt machine and it was all ok.
