build: b2019031202
os: win 10 pro
I’m not sure exactly what caused this npe but I think it was when I was trying to copy a cell values from a Table component. No rush on this but I wanted to relay.
| Routes | 12Mar2019 16:13:23 | Problem copying font input stream to the servlet response output stream |
| org.eclipse.jetty.io.EofException: null |
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:292)
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429)
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:322)
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:372)
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:794)
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241)
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224)
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:528)
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:783)
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:834)
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:234)
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:218)
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:509)
at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:1384)
at org.apache.commons.io.IOUtils.copy(IOUtils.java:1357)
at com.inductiveautomation.perspective.gateway.comm.Routes.getFont(Routes.java:577)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:247)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:49)
at com.inductiveautomation.ignition.gateway.dataroutes.DataServlet.service(DataServlet.java:87)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at java.base/sun.nio.ch.SocketDispatcher.writev0(Native Method)
at java.base/sun.nio.ch.SocketDispatcher.writev(Unknown Source)
at java.base/sun.nio.ch.IOUtil.write(Unknown Source)
at java.base/sun.nio.ch.SocketChannelImpl.write(Unknown Source)
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:272)
… 52 common frames omitted|
