BUG - Simple Table Object Reporting Module
Hi all,
Just reporting a quirk here. I tried to use some expression syntax for binding the visibility of the simple table component, kept getting errors and no function out of it. Played around with a text label, got the expression working for the visibility, bound that to the table, errors come back. Then added a “advanced” table or normal table component and added the binding to its visibility, and what do you know it works there as well. I know that the reporting module is a bit outdated and has enough legacy stuff to make it hard to update but it REALLY needs an update with modern reporting needs.
Heres the report designer, label, simple table, then regular table
Here’s it with the filter satisfied (the test label, simple table and then normal table component all working.
Then changing the parameters default value so all 3 should no longer be visible, but the simple table remains.
