[BUG?] SVG Component Handles Inadvertently Rotated
So I had worked up and example for this thread. Today I noticed that when you click on svg component, you're greeted with some interesting graphics.
It could be something I've done incorrectly, but I thought I would report it here none the less. Not drastic enough that I feel a formal bug report is needed until someone confirms that I haven't caused this with myself.
spinner
Stylesheet CSS:
:root {
	--spinner-animation-speed: 1s;
@keyframes spin {
	from {
		transform: rotate(0deg);
	to {
		transform: rotate(360deg);
.psc-spinner {
	animation: spin var(--spinner-animation-speed) linear infinite;
View JSON:
  "custom": {},
  "params": {},
  "props": {
    "defaultSize": {
      "height": 422,
      "width": 573
  "root": {
    "children": [
        "meta": {
          "name": "blank"
        "position": {
          "height": 176,
          "width": 155,
          "x": 183,
          "y": 106
        "props": {
          "elements": [
              "elements": [
                  "elements": [
                      "offset": "0%",
                      "stopColor": "value",
                      "type": "stop"
                      "offset": "25%",
                      "stopColor": "#07c",
                      "stopOpacity": "75%",
                      "type": "stop"
                      "offset": "50%",
                      "stopOpacity": "50%",
                      "type": "stop"
                      "offset": "75%",
                      "stopOpacity": "25%",
                      "type": "stop"
                      "offset": "100%",
                      "stopOpacity": "5%",
                      "type": "stop"
                  "id": "fade",
                  "type": "linearGradient",
                  "x1": "1%",
                  "x2": "80%",
                  "y1": "95%",
                  "y2": "15%"
              "type": "defs"
              "cx": 24,
              "cy": 24,
              "fill": "transparent",
              "r": 22,
              "stroke": {
                "paint": "url(#fade)",
                "width": 4
              "type": "circle"
          "style": {
            "classes": "spinner"
          "viewBox": "0 0 48 48"
        "type": "ia.shapes.svg"
    "meta": {
      "name": "root"
    "type": "ia.container.coord"
Probably unavoidable. You're altering the component via the stylesheet at the same "layer" the designer itself works at.
