DataType property is not returned for an integer tag:
A real and boolean is fine:
Real:
Real:
It only returns it once it has been changed
Hmm. I suspect that’s because Int is the default datatype and default values aren’t serialized.
Yes that seems to be the case which is a problem. I am trying to switch between different views based on the datatype of the tag.
Will this be fixed in a future release, or is there a workaround?
