v8.0.15
When using the choose tag icon to select a tag within the UDT you’re editing, selecting UDT gets you to the root of the tag browser; you then need to manually find the UDT you’re editing from the tree. Ideally, you should only be able to see the structure from the root of the UDT definition, as was the case in v7.
