I am trying to do some stuff that leverages CSS layers, however whenever I try to add a layer to the native light.css or dark.css themes it gives me a null pointer when trying to strip comments from the CSS.
I am guessing this is a bug, unfortunately, but any ideas how to achieve the same goal?
modules/com.inductiveautomation.perspective/themes/light.css
@import "./light/index.css" layer(ignition);
The NPE
java.lang.NullPointerException: Cannot invoke "String.replaceAll(String, String)" because "css" is null
at com.inductiveautomation.perspective.gateway.assets.themes.ThemeManagerImpl.removeComments(ThemeManagerImpl.java:421)
at com.inductiveautomation.perspective.gateway.assets.themes.ThemeManagerImpl.processTheme(ThemeManagerImpl.java:258)
at com.inductiveautomation.perspective.gateway.assets.themes.ThemeManagerImpl.lambda$onCacheChanged$5(ThemeManagerImpl.java:248)
at java.base/java.util.HashMap.forEach(Unknown Source)
at com.inductiveautomation.perspective.gateway.assets.themes.ThemeManagerImpl.onCacheChanged(ThemeManagerImpl.java:246)
at com.inductiveautomation.perspective.gateway.assets.AbstractAssetManager.onCreateOrModify(AbstractAssetManager.java:481)
at com.inductiveautomation.perspective.gateway.assets.AbstractAssetManager.onWatchEvent(AbstractAssetManager.java:160)
at com.inductiveautomation.perspective.gateway.files.FileWatcher.processWatchEvent(FileWatcher.java:204)
at com.inductiveautomation.perspective.gateway.files.FileWatcher.lambda$processWatchKey$0(FileWatcher.java:234)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.inductiveautomation.perspective.gateway.files.FileWatcher.processWatchKey(FileWatcher.java:234)
at com.inductiveautomation.perspective.gateway.files.FileWatcher.processFileChanges(FileWatcher.java:260)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Essentially I have some other theming I want to prioritize, that is using layering, and I want it to take precedence over the native themes.
@layer ignition, theme, base, components, utilities;
