Ignition 8.1.28
Hello,
We have some reference tags used with the following pattern :
- reference tags "mytagA" : sourcetagPath : "mytagA_pri" or "mytagA_sec"
- opc tags "mytagA_pri"
- opc tags "mytagA_sec"
We have some history configured for "mytagA"
Each time we change the sourcetagPath of "mytagA" some exception "Violation of PRIMARY KEY constraint"
This change trigger the history insert and because "mytagA_pri" and "mytagA_sec" have the same Value/Quality/Timestamp an exception is generated.
It seems to be a bug. The change of "sourcetagPath" for reference tags must not trigger an history recorded if the target Value/Quality/Timestamp has no change !
java.lang.RuntimeException: java.sql.BatchUpdateException: Batch entry 3 INSERT INTO sqlt_data_1_2023_06("tagid", "intvalue", "floatvalue", "stringvalue", "datevalue", "dataintegrity", "t_stamp") VALUES(5387,0,NULL,NULL,NULL,192,1686031757943) was aborted: ERREUR: la valeur d'une clé dupliquée rompt la contrainte unique « sqlt_data_1_2023_06_pkey » Détail : La clé « (tagid, t_stamp)=(5387, 1686031757943) » existe déjà. Call getNextException to see other errors in the batch.
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:47)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.stream.Streams$StreamBuilderImpl.forEachRemaining(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:186)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:156)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:180)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:147)
Caused by: java.sql.BatchUpdateException: Batch entry 3 INSERT INTO sqlt_data_1_2023_06("tagid", "intvalue", "floatvalue", "stringvalue", "datevalue", "dataintegrity", "t_stamp") VALUES(5387,0,NULL,NULL,NULL,192,1686031757943) was aborted: ERREUR: la valeur d'une clé dupliquée rompt la contrainte unique « sqlt_data_1_2023_06_pkey » Détail : La clé « (tagid, t_stamp)=(5387, 1686031757943) » existe déjà. Call getNextException to see other errors in the batch.
at org.postgresql.jdbc.BatchResultHandler.handleError(BatchResultHandler.java:165)
at org.postgresql.core.ResultHandlerDelegate.handleError(ResultHandlerDelegate.java:52)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2367)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2099)
at org.postgresql.core.v3.QueryExecutorImpl.flushIfDeadlockRisk(QueryExecutorImpl.java:1456)
at org.postgresql.core.v3.QueryExecutorImpl.sendQuery(QueryExecutorImpl.java:1481)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:546)
at org.postgresql.jdbc.PgStatement.internalExecuteBatch(PgStatement.java:893)
at org.postgresql.jdbc.PgStatement.executeBatch(PgStatement.java:916)
at org.postgresql.jdbc.PgPreparedStatement.executeBatch(PgPreparedStatement.java:1684)
at org.apache.commons.dbcp2.DelegatingStatement.executeBatch(DelegatingStatement.java:242)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeBatch(DelegatingStatement.java:60)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeBatch(SRConnectionWrapper.java:767)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink$BatchedTagInsert.onComplete(TagHistoryDatasourceSink.java:1296)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.insertTagValues(TagHistoryDatasourceSink.java:1088)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeScanClassSet(TagHistoryDatasourceSink.java:550)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeDataToDatasource(TagHistoryDatasourceSink.java:525)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.lambda$storeToDatasource$2(AbstractDatasourceSink.java:186)
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:45)
... 18 common frames omitted
Caused by: org.postgresql.util.PSQLException: ERREUR: la valeur d'une clé dupliquée rompt la contrainte unique « sqlt_data_1_2023_06_pkey » Détail : La clé « (tagid, t_stamp)=(5387, 1686031757943) » existe déjà.
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2676)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2366)
