v7.9.10
As described in the title, a List component doesn’t generate events when you use the arrow keys holding down Shift to multi-select items from the list.
v7.9.10
This a long-standing problem, because there isn’t a bindable property for selectedItems. If you teach your users to shift-click in reverse, so the first item desired is the last selected, monitoring selectedItem will suffice. Yeah, not great. /-:
