Regarding IgnitionOPCUA:
When I change the admin account’s default password, IgnitionOPCUA status changes from good, to faulted. As soon as I change the admin account password back to ‘password’, the status returns to normal. (I was able to change the admin account password before without encountering this error)
[quote]java.lang.Exception: Could not activate sesssion: Bad_UserAccessDenied
com.inductiveautomation.xopc.client.srremoteserver.DefaultSRRemoteServer.activateSession(DefaultSRRemoteServer.java:306)
com.inductiveautomation.xopc.client.srremoteserver.DefaultSRRemoteServer.connect(DefaultSRRemoteServer.java:177)
com.inductiveautomation.xopc.client.sropcserver.OPCUAServer.connect(OPCUAServer.java:420)
com.inductiveautomation.xopc.client.sropcserver.OPCUAServer.connectToServer(OPCUAServer.java:395)
com.inductiveautomation.xopc.client.sropcserver.OPCUAServer.verifyConnectionState(OPCUAServer.java:446)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.verifyConnectionState(OPCManagerImpl.java:665)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$OPCConnectionKeepalive.run(OPCManagerImpl.java:552)
com.inductiveautomation.ignition.gateway.execution.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:403)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:317)
java.util.concurrent.FutureTask.runAndReset(FutureTask.java:150)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:98)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(ScheduledThreadPoolExecutor.java:181)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:205)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:619)[/quote]
