Hi Team,
I am facing issue while creating module, I followed the forms, my problem is same as specified below link Building new module in Maven
Here is the plugin code
<plugin>
<groupId>com.inductiveautomation.ignitionsdk</groupId>
<artifactId>ignition-maven-plugin</artifactId>
<version>1.2.0</version>
<executions>
<execution>
<phase>package</phase>
<goals>
<goal>modl</goal>
</goals>
</execution>
</executions>
<configuration>
<projectScopes>
<projectScope>
<name>customauth-gateway</name>
<scope>G</scope>
</projectScope>
</projectScopes>
<moduleId>{project.moduleId}</moduleId>
<moduleName>{project.moduleName}</moduleName>
<moduleDescription>Module for authorizatition </moduleDescription>
<moduleVersion>1.2.1</moduleVersion>
<requiredIgnitionVersion>8.1.16</requiredIgnitionVersion>
<requiredFrameworkVersion>8</requiredFrameworkVersion>
<hooks>
<hook>
<scope>G</scope>
<hookClass>{package}.GatewayHook</hookClass>
</hook>
</hooks>
</configuration>
</plugin>
Added this plugin to create a module.
Getting this error
Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.2.0:modl (default) on project customauth-gateway: Execution default of goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.2.0:modl failed.: NullPointerException
Please let me know what is wrong here.
Thanks,
Naveen Batchu.
Is there a stack trace or any additional information to go with that NullPointerException?
Stacktrace of the error
[WARNING] Error injecting: com.inductiveautomation.ignitionsdk.IgnitionModlMojo
java.lang.TypeNotPresentException: Type com.inductiveautomation.ignitionsdk.IgnitionModlMojo not present
at org.eclipse.sisu.space.URLClassSpace.loadClass (URLClassSpace.java:147)
at org.eclipse.sisu.space.NamedClass.load (NamedClass.java:46)
at org.eclipse.sisu.space.AbstractDeferredClass.get (AbstractDeferredClass.java:48)
at com.google.inject.internal.ProviderInternalFactory.provision (ProviderInternalFactory.java:85)
at com.google.inject.internal.InternalFactoryToInitializableAdapter.provision (InternalFactoryToInitializableAdapter.java:57)
at com.google.inject.internal.ProviderInternalFactory$1.call (ProviderInternalFactory.java:66)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision (ProvisionListenerStackCallback.java:112)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision (ProvisionListenerStackCallback.java:127)
at com.google.inject.internal.ProvisionListenerStackCallback.provision (ProvisionListenerStackCallback.java:66)
at com.google.inject.internal.ProviderInternalFactory.circularGet (ProviderInternalFactory.java:61)
at com.google.inject.internal.InternalFactoryToInitializableAdapter.get (InternalFactoryToInitializableAdapter.java:47)
at com.google.inject.internal.InjectorImpl$1.get (InjectorImpl.java:1050)
at org.eclipse.sisu.inject.Guice4$1.get (Guice4.java:162)
at org.eclipse.sisu.inject.LazyBeanEntry.getValue (LazyBeanEntry.java:81)
at org.eclipse.sisu.plexus.LazyPlexusBean.getValue (LazyPlexusBean.java:51)
at org.codehaus.plexus.DefaultPlexusContainer.lookup (DefaultPlexusContainer.java:263)
at org.codehaus.plexus.DefaultPlexusContainer.lookup (DefaultPlexusContainer.java:255)
at org.apache.maven.plugin.internal.DefaultMavenPluginManager.getConfiguredMojo (DefaultMavenPluginManager.java:520)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:124)
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute (MojoExecutor.java:301)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:211)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:165)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:157)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:121)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:127)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:294)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:960)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:293)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:196)
at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke (Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
Caused by: java.lang.UnsupportedClassVersionError: com/inductiveautomation/ignitionsdk/IgnitionModlMojo has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0
at java.lang.ClassLoader.defineClass1 (Native Method)
at java.lang.ClassLoader.defineClass (ClassLoader.java:756)
at java.security.SecureClassLoader.defineClass (SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass (URLClassLoader.java:473)
at java.net.URLClassLoader.access$100 (URLClassLoader.java:74)
at java.net.URLClassLoader$1.run (URLClassLoader.java:369)
at java.net.URLClassLoader$1.run (URLClassLoader.java:363)
at java.security.AccessController.doPrivileged (Native Method)
at java.net.URLClassLoader.findClass (URLClassLoader.java:362)
at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClassFromSelf (ClassRealm.java:425)
at org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy.loadClass (SelfFirstStrategy.java:42)
at org.codehaus.plexus.classworlds.realm.ClassRealm.unsynchronizedLoadClass (ClassRealm.java:271)
at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass (ClassRealm.java:247)
at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass (ClassRealm.java:239)
at org.eclipse.sisu.space.URLClassSpace.loadClass (URLClassSpace.java:139)
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 1.837 s
[INFO] Finished at: 2022-04-25T16:07:57-04:00
[ERROR] Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.2.0:modl (default-cli) on project customauth-gateway: Execution default-cli of goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.2.0:modl failed: Unable to load the mojo 'modl' in the plugin 'com.inductivea
utomation.ignitionsdk:ignition-maven-plugin:1.2.0' due to an API incompatibility: org.codehaus.plexus.component.repository.exception.ComponentLookupException: com/inductiveautomation/ignitionsdk/IgnitionModlMojo has been compiled by a more recent version of the Java Runtime (class file version 55.0), this versi
[ERROR] -----------------------------------------------------
[ERROR] realm = plugin>com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.2.0
It looks like the actual problem is you’re trying to use an old version of Java…
Thanks @Kevin.Herron, Updated to java version able to create module.
