How would you write or can you write this expression. These are all opc tags. Where can I find info on writing expressions.
If value1 > Value2 then
Bit1=1 else
Bit1=0
Bit1=1 else
Bit1=0
Bind Bit1 to the expression: "value1 > Value2".
You could also do:
Read about expressions in the FactoryPMI manual here.
[quote="raw1312"]How would you write or can you write this expression. These are all opc tags. Where can I find info on writing expressions.
Bit1=1 else
Bit1=0[/quote]
