Sure - I’ll also add the modules.xml file.
java.lang.Exception: Exception parsing “module.xml”
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.parseModuleInfo(ModuleManagerImpl.java:1644)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.extractModuleInfo(ModuleManagerImpl.java:1637)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage.eulaCertCheck(ModuleInstallPage.java:120)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage$1.onSubmitInternal(ModuleInstallPage.java:71)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:67)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1248)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1242)
at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274)
at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1241)
at org.apache.wicket.markup.html.form.Form.process(Form.java:923)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:769)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:702)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:240)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:226)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at com.inductiveautomation.ignition.gateway.bootstrap.GatewayFilter.doFilter(GatewayFilter.java:74)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1629)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:533)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
Caused by: java.lang.IllegalArgumentException: Invalid version: “1.0”
at com.inductiveautomation.ignition.common.model.Version.(Version.java:87)
at com.inductiveautomation.ignition.common.model.Version.parse(Version.java:246)
at com.inductiveautomation.ignition.common.modules.ModuleInfoParser.endElement(ModuleInfoParser.java:138)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.modules.ModuleInfoParser.fromXML(ModuleInfoParser.java:241)
And the modules.xml file:
com.lamtec.IgnitionWebService
IgnitionWebService Ignition Module
1.0
8.0.1
IgnitionWebService-common-1.0.jar
IgnitionWebService-gateway-1.0.jar
javaee-api-7.0.jar
IgnitionWebService-client-1.0.jar
IgnitionWebService-designer-1.0.jar
com.lamtec.ignitionwebservice.client.ClientHook
com.lamtec.ignitionwebservice.designer.DesignerHook
com.lamtec.ignitionwebservice.GatewayHook
