Is there a method to execute a bulk modification of a property for a specified component type in ignition? For instance, let's say I want to set the "mode" of all coordinate containers from "percent" to "fixed".
You can edit the json of your views to do this. Every view is stored in the file system as a json file, so you can fairly easily loop through those you want to update and modify the json. Or, if you only want to do it on a single view, or less automated, then you can copy the json of the view from the designer (shift+right click, copy json) , and process that, then paste json back
